Автомобилка QUANSHENG TG-286/386/486
| radioproffi1 | Дата: Понедельник, 2011-11-28, 8:59 PM | Сообщение # 1 |
| Вот пошли первые ласточки от китай-прома по автомобильным радиостациям . 1. Menu setting 2. Work by repeater station 3. Auto Repeater Offset Frequency 4. Time-Out-Timer 5. Memory Channel, Channel Lockout 6. Channel name & Frequency Display 7. Scanning, Priotiry scanning, Scan Reset 8. CTCSS,DCS 9. DTMF function, Hold,Pause, Lock ,Monitor 10. APO (Auto power-off) 11. Beat Frequency Deviation 12. S-meter signal indicates squelch 13. Squelch Holding Time settable 14. Prompt Tone 15. Busy Channel Lockout 16. LCD backlight 17. Keypad Lock function 18. Channel Frequency Step 19. Tone Frequency 20. Output Power Selective 21. Programmable VFO 22. Power on Message 23. Narrow Frequency Adjustment 24. Controlling Knob Lock 25. Microphone Lock,Mic Programmable menu 26. 1750Hz Transmit Hold 27. Call keypad
Specification Frequency range (TX) TG-286 (Market M3): 136-174MHz TG-386: 350-390MHz TG-486 (Market C): 400-430MHz TG-486 (Market C2): 440-480MHz TG-486 (Market C3): 400-470Mhz Frequency range (RX) TG-286 (Market M3): 136-174MHz TG-386: 350-390MHz TG-486 (Market C): 400-430MHz TG-486 (Market C2): 440-480MHz TG-486 (Market C3): 400-470Mhz Modulation mode F3E(FM) Antenna impedance 50Ω Rated voltage 13.8V Current Transmitting <12A Receiving <1.0A (Output 2W) Frequency stability ≤±2.5PPm Transmitting Output power VHF: 60W(H) 25W(LOW) UHF: 40W(H) 25W(LOW) Reactance modulation Reactance Modulation limit 25KHz±5KH, 12.5KHz±2.5KHz Audio distortion <5% Adjacent channel power 25KHz≥65dB, 12.5KHz≥60dB Stray radio frequency measure <-60dB Modulation character 3dB~-3dB (Modulation frequency: 300Hz~3KHz) Receiving Circuitry Adopt quadratic frequency conversion superheterodyne mode Mid-frequency (1st/2nd) 49MHz,450Khz Sensitivity 25KHz<0.2μV, 12.5KHz<0.25μV Selectivity minus 6dB 25KHz<12KHz, 12.5KHz<10KHz minus 60dB 25KHz<30KHz, 12.5KHz<24KHz Same channel restrain >-8dB Adjacent channel selective 25KHz≥65dB, 12.5KHz≥60dB Stray response anti-interference 25KHz≥65dB, 12.5KHz≥60dB Intermodulation anti-interference 25KHz≥60dB, 12.5KHz≥55dB Blocking ≥90dB Audio response 1dB~-3dB (Modulation frequency: 300Hz~3KHz) Audio distortion <5% (>2W)(Microphone internal resistance is 8Ω
| radioproffi1 | Дата: Понедельник, 2011-11-28, 9:02 PM | Сообщение # 2 |
| ROM | Дата: Суббота, 2011-12-31, 9:09 PM | Сообщение # 3 |
| есть в продаже?
| BRAMBUL | Дата: Понедельник, 2012-01-02, 1:47 AM | Сообщение # 4 |
| Мда уж таки Великая страна Китай , так и до КВ глядишь доберутся?!
| radioproffi1 | Дата: Понедельник, 2012-01-02, 1:09 PM | Сообщение # 5 |
| ROM, Пока только в планах продажа этих станций .
BRAMBUL, до кв я думаю тоже доберутся.
| BRAMBUL | Дата: Понедельник, 2012-01-02, 5:29 PM | Сообщение # 6 |
| не знаю как по качеству конструкторско-схемотехническая часть, но судя по фото "болторезный" факультет радиоприборостроительного техникума в Китае пять баллов, я в смысле-корпус с виду более чем добротный.
| radioproffi1 | Дата: Среда, 2012-01-04, 12:06 PM | Сообщение # 7 |
| BRAMBUL, да а корпуса китайцы умеют делать , хотя и начинка там отличная.
