| Alexmen | Дата: Суббота, 2018-11-17, 11:34 AM | Сообщение # 1 |
| 0961832525 ur5tka@gmail.comСостояние хорошее. Работает отлично. Железный корпус. Тип элемента микрофона- электретный. Подходит к любим трансиверам. Микрофон без кабеля подключения. Могу спаять под Icom. гнезда на микрофоне RG45 расспиновка есть. цена-100у.е
PDF http://www.commco.co.za/avair_AV-908.pdf
Описания с интернета:
High Sensitivity Ceramic Microphone Elements equipped High Quality Compressor Amplifier (High, Med., Low Selectable) built-in.
It sends out always constant and optimum Level without distortion regardless of audio input level Equipped with Graphic Equalizer for Optimum Audio Quality Control.
The Audio Quality can be controlled by 4 Element Graphic Equalizer with Center Frequencies of 270, 540, 1000 And 2000Hz. It gives best Audio Quality for FM mode and Maximum efficiency for SSB mode DX
Non-Modulation Prevention Circuit built-in After continuous transmitting for a few minutes, the alarm circuit will be activated with alarm sound for 30 seconds.
Then, the condition returns to the receiving mode automatically Battery-Check Circuit built-in Press the power switch and the level meter indicates the battery condition with power voltage for a few seconds
SPECIFICATIONS
Microphone:
High Sensitivity Ceramic Mic.
Element Compressor Level: HIGH: 45 dB, MED: 30 dB, LOW: 10 dB
S/N Ratio (Graphic Equalizer Part): 80dB Distortion Factor (Graphic Equalizer Part): 0.05%(at flat)
Graphic Equalizer: 4 elements (270,540,1000,2000Hz) +12dB range
Output Voltage:
COMP: 0- 30mV (RMS) Matching Output Impedance: 500 ohms – 100K ohms
Power Voltage: DC 6~9 V Current Consumption: Receiving: 3.5mA (at Equalizer “Off”)
Transmitting: 4.5mA (at Equalizer “Off”) Receiving: 10mA (at Equalizer “On”)
Transmitting: 11mA (at Equalizer “On”)
Alarm Sound: Approx. 4.5KHz Intermittent Tone
External Size: 227(W) x 130(D) x 320(H) mm
Weight: Approx. 1000 gr.
COMES WITH FREE ICOM CABLE
