Wouxun KG-UV920R
| Pulse | Дата: Четверг, 2013-01-03, 5:00 AM | Сообщение # 31 |
| Кто заливал частоты в эту радиостанцию? Каким кабелем, есть ли точная распиновка разъёма станции? Программатором от кенвуда и распайкой, как показано на форумах не прокатывает...
| aaaaa-raz | Дата: Пятница, 2013-01-25, 2:37 AM | Сообщение # 32 |
| воуксон по описанию класная штука , а как насчет вот этого ? у вас в магазине будит ? http://www.wouxun.us/item.php?item_id=295&category_id=64
AnyTone AT-5888UV
*** This is NOT a Wouxun radio, it is made by AnyTone ***
Features added for final-production radios: Updated Microphone -- Added a built-in speaker in mic's front & a switch to defeat the Channel Up/Down button (which was easy to accidently hit). This switch was also supposed to lock all buttons on the mic, but not sure about that yet. Updated Firmware -- Several menu functions have been added. See the owner's manual for all functions. FCC Part 90 Certified -- ID # T4K-5888UV
Features: Receive Range (FM) 220-260, 350-400, 400-520 MHz 108-180 MHz (AM or FM Mode) 118-134 MHz (AM Aircraft Band) Transmit Range (FM) 134-174, 400-490 MHz Output Power 50, 35, 10 & 5 Watts Bandwidth Wide (25 kHz) & Medium (20 kHz) & Narrow (12.5 kHz) Tuning Step 2.5, 5, 6.25, 10, 12.5, 15, 20, 25 & 50 kHz True Dual Receive - receive two signals at the same time -- second side can be muted while transmitting Separate Tuning Knob and Volume Control, each side Separate Function Buttons, each side Either side can be VHF or UHF at any time - VU, UV, UU, VV - One side can be VFO and the other side Memory at the same time Cross-Band Repeat (that works!) Alphanumeric Display 4 x 256 Memory Channels CTCSS, DCS, DTMF, ANI, PTT ID, 2Tone/5Tone Encode & Decode Scrambler Included DTMF Microphone Detachable Control Head (CAT5 separation cable) Computer Programmable All buttons on radio and mic are back-lighted FCC Part 90 Certified (FCC ID is T4K-5888UV) по описанию заокеанских друзей переплюнет воуксон и по цене и по приемнику . привезите спрос будет .
Take a ride
Сообщение отредактировал aaaaa-raz - Пятница, 2013-01-25, 2:45 AM |
| tem | Дата: Вторник, 2013-02-19, 11:57 PM | Сообщение # 33 |
| Андрей, Воксуны 920-е появились, смотрю? Отложите, пожалуйста, один комплект - воксун + нагойя двухдиапазонная + магнит. Я щас в Харькове, через неделю вернусь и заберу Просто просьба, если их, вдруг, разметать быстро начнут...
| Fitilek | Дата: Воскресенье, 2013-04-07, 3:22 PM | Сообщение # 34 |
| KG- UV950P Андрей а данный девайс ожидается? И какова ориентировочная цена?
www.teplodnepr.com.ua
| radioproffi1 | Дата: Понедельник, 2013-10-07, 10:40 PM | Сообщение # 35 |
| radioproffi1 | Дата: Понедельник, 2013-10-07, 10:42 PM | Сообщение # 36 |
Низкий 1 (H) /2 (L) Высокий 26,000 МГц 4.0 9,5 / 9,5 9,5 27,000 МГц 3,6 9,5 / 9,5 9,5 28,000 МГц 3,7 9,0 / 9,0 9,0 29,000 МГц 3,7 9,0 / 9,0 9,0 29,995 МГц 3,5 8,1 / 8,1 8,1 52,000 МГц 2,8 13,1 / 6,8 32,2 145,000 МГц 4,2 20,0 / 9,5 42,7 435,000 МГц 3,5 14,5 / 7,5 35,3
| radioproffi1 | Дата: Вторник, 2013-10-08, 10:09 PM | Сообщение # 37 |
| Павел | Дата: Вторник, 2013-10-08, 10:24 PM | Сообщение # 38 |
| Как я понимаю разьем антенный там один, и надо где то брать КВАДРО антенну:) ну или хотябы на три диапазона:) 27, 144,430 МГц
А вобще интересный аппарат, как раз в авто можно смело ставить:)
| diman70me | Дата: Вторник, 2013-10-08, 10:37 PM | Сообщение # 39 |
| присоединяюсь к Паше,интересный очень.
UW5EHM
| radioproffi1 | Дата: Вторник, 2013-10-08, 11:15 PM | Сообщение # 40 |
| В принципе я думаю можно через дуплексер вывести на разные антенны или 50 и 27 вывести отдельным кабелем с разъемом.
| cbmaster | Дата: Вторник, 2013-12-17, 0:34 AM | Сообщение # 41 |
| Здравствуйте! Будет ли ещё данная радиостанция в продаже в этом году?
CB-MASTER, 73!
| radioproffi1 | Дата: Вторник, 2013-12-17, 11:16 AM | Сообщение # 42 |
| В этом году уже не будет, вся партия распродана, будут 950 модели.
| Павел | Дата: Вторник, 2013-12-17, 4:51 PM | Сообщение # 43 |
| С нетерпением ждем 950-ю
| cbmaster | Дата: Среда, 2013-12-18, 1:51 AM | Сообщение # 44 |
| А мне бы хотелось именно 920-ю. Не вижу смысла в мультидиапазонности 950-й, а также сильно смущает наличие НЧ-реле как таковых, даже на 27/50 МГц. И, 50 МГц это в основном телеграфный диапазон, врятли кто-то оценит его наличие как достоинство. Моё мнение 144/430 именно то, что нужно для УКВ радиостанции, а 26-30 извините - это уже короткие волны. Да ещё и в один разъём... В общем без напильника и в этот раз не обойдётся .
CB-MASTER, 73!
| Vlad | Дата: Суббота, 2014-03-01, 4:19 PM | Сообщение # 45 |
| Получил не давно 920р Сделана добротно и качественно,если бы не знал что из Китая ,даже и мысли не возникло.Чем отличается от 920R не знаю,нашёл только отличие в 41 меню ,у меня стоит "RPT TONE".Инструкцию скачал от 920R,много не понятно,например как настроить сканирование участка диапазона,,как настроить группы каналов,Если кто знает просветите . Методом тыка нашёл интересные фишки: Если зажать кнопку 1 и включить аппарат,то появиться менюшка с надписью "PRESS1,затем нажимая кнопку 1 можно узнать серийный номер,номер прошивки,дату изготовления Если зажать кнопку 6 и включить аппарат появляеться надпись CommUtai on Data,не знаю для чего ,может для программирования если зажать кнопку 7 и включить аппарат на дисплее высветятся свсе знаки ,которые есть на этом ЖКИ. Кто нибудь знает как настроить сканирование участка диапазона
