WOUXUN KG-UV6D новая версия популярной радиостанции - Форум про радио
  • Страница 1 из 16
  • 15
  • 16
radioproffi1Дата: Суббота, 2011-12-24, 0:43 AM | Сообщение # 1
В свет вышла новая версия этой супер популярной радиостанции .
Прикрепления: 7481486.jpg (64.0 Kb) · 6149176.jpg (55.3 Kb) · 1420074.jpg (84.6 Kb) · 0944681.jpg (83.4 Kb)
radioproffi1Дата: Суббота, 2011-12-24, 0:45 AM | Сообщение # 2
Сервис мануал на WOUXUN KG-UV6D
схема принципиальная
radioproffi1Дата: Суббота, 2011-12-24, 0:47 AM | Сообщение # 3
Описание с сайта производителя
Dual band monitor (VHF/UHF, VHF/VHF, UHF/UHF)
Dual alpha numeric, backlit display with channel name edit
Selectable high/low power settings (VHF: 5W high/2W low) (UHF: 4W high/2W low)
Includes extended life high capacity li-ion battery as standard
Includes intelligent desktop 3-4 hour rapid charger
Loud speaker audio output (500 mW)
Bright flashlight illumination function
Meets IP55 waterproof rating
English female voice prompts enable non-sighted operation (can be turned off)
128 memory channels (shared)
VOX Function
Digital FM radio (76-108MHz) with automatic tuning and storing, radio frequency display, 18 FM memories in 2 banks
Wide/narrow bandwidth selection (25 or 12.5 kHz)
Power on display: show battery voltage, 6-character customizable welcome message, or display test
Windows PC programmable, free software available for download. Optional low cost cable (SKU: WXUSB or WXSER) required.
Radio to radio cloning with optional cable (SKU: WXCLN)
Same channel: VHF TX & UHF RX or UHF TX & VHF RX available
105 groups DCS/50 groups CTCSS
DTMF encoding (includes ABCD tones, continuous with button press duration)
CTCSS encode/Decode (no decode delay)
Stopwatch function
SOS function
Low-voltage voice prompt
Busy channel lockout
Selectable transmit over timer (from 15 to 600 seconds)
Selectable step sizes of 5, 6.25, 10, 12.5, 25, 50 or 100 kHz
Multiple scan modes including priority scan
Keypad lock (auto or manual)
Programmable by computer
High contrast white backlit keypad. All keys are backlit (except A/B, S/D & RPT)
Specifications
KG-UV6D
Frequency Range (RX/TX)
VHF: 136-174 MHz
UHF: 400-480 MHz
FM: 76-108 MHz (RX only)
Memory Channels
199 channels (shared)
Operating Voltage
7.4 VDC
Operating Temperature
-22°F to 140°F (-30°C to +60°C)
Dimensions (W x H x D)
2.6 x 4.7 x 1.6 inches (65 x 119 x 39.5mm) (without antenna)
Weight
8.9 ounces (253 grams)
RF Carrier Power
VHF: 5W high/2W low, UHF: 4W high/2W low
Audio Output Power
500mW
Waterproof Rating
Antenna Impedance
50Ω
Sensitivity (12dB SINAD)
0.16 µV
Receive/Squelch Sensitivity
≤0.2 µV
Audio Distortion
≤5%
Audio Modulation
+3dB (pre-emphasis by 6dB between 0.3-3KHz)
Audio Response
(300-3,000Hz) +1 to -3dB
Performance of Amplitude Limiter
≤3
Effective Radiation Power (ERP)
within pre-determined value ≤±7.5dB
Maximum Frequency Deviation
25KHz ± 5KHz
Inter Modulation Attenuation
≥40dB
Modulation Distortion
≤10%
Co-channel Rejection
≥-8.0dB
Adjacent Channel Selection
Channel Space: 25KHz ≥ 70dB
Channel Space: 12.5KHz ≥ 60dB
Inter-modulation
≥ 65dB
Radiation
≥84dB
Spurious Radiation
9KHz to 1GHz ≤ -57dBm / 1GHz to 4GHz ≤ -47dBm
radioproffi1Дата: Суббота, 2011-12-24, 1:27 AM | Сообщение # 4
Как попадет лично в руки сделаю полный обзор WOUXUN KG-UV6D
temДата: Воскресенье, 2011-12-25, 1:47 PM | Сообщение # 5
А чем она принципиально от UVD1P отличается? Кроме того, что в режиме Low мощность 2Вт вместо 1, кроме приветствия, которое можно самостоятельно менять и кроме водозащиты...
Новая кнопка бросилась в глаза (над TDR).
И цена в 1.5 раза выше biggrin
Сидят себе радиолюбители...
...и дружно ЛЮБЯТ РАДИО!
balmeoДата: Воскресенье, 2011-12-25, 11:16 PM | Сообщение # 6
Влагозащита, иногда очень бывает полезной!
077 Сергей
radioproffi1Дата: Понедельник, 2011-12-26, 4:21 PM | Сообщение # 7
Данная версия через три недели будет уже в продаже в интернет магазине .
Станций версии 1P осталось совсем немного .
temДата: Понедельник, 2011-12-26, 11:59 PM | Сообщение # 8
Сделали бы китайцы АМ хотябы на приём - цены не было бы... (и диапазон чуток пошире...) А так - я просто смысла не вижу в этой модели... Сколько она стоить будет вообще? (для сравнения с UVD1P...)
radioproffi1Дата: Вторник, 2011-12-27, 0:14 AM | Сообщение # 9
как приедут скажу smile
nicksnnДата: Среда, 2012-02-15, 8:31 PM | Сообщение # 10
интересная модель, но не понравилось крепление ремешка для переноса, без клипсы его нету куда прикрепить. При работе даже в режиме сканера начинают прогреваться бока и часть корпуса под аккумулятором. на первый взгляд очень неудобным показалось внесение каналов в память с клавиатуры самой рации. немного потеплеет пройдут полевые испытания.
radioproffi1Дата: Среда, 2012-02-15, 10:25 PM | Сообщение # 11
Программировать каналы памяти удобнее всего на компьтере , просто и быстро .
nicksnnДата: Четверг, 2012-02-16, 11:29 PM | Сообщение # 12
подскажите, можно ли спаять гарнитуру с птт так чтобы с нее можно было выбирать активный канал передачи а или б?
ЗЫ таки нашол кабель и запихнул в память порядка 100 каналов
ПавелДата: Пятница, 2012-02-17, 0:05 AM | Сообщение # 13
Аж 100 каналов...офигительно,неужели у нас в Днепропетровске есть что послушать/сработать с кем то,аж не верится в 100 каналов wacko
nicksnnДата: Пятница, 2012-02-17, 0:25 AM | Сообщение # 14
а я незнаю как у вас в днепре, но я простовпихнул все лпд, фрс и пмр каналы )))
ПавелДата: Пятница, 2012-02-17, 3:47 PM | Сообщение # 15
Понял Вас cool
  • Страница 1 из 16
  • 15
  • 16
